LAG port not found for link, lif
Check the port instance and check if the corresponding LAG exists. Use a valid instance to search for the corresponding LAG. show lacp show lacp member-port <port> {detail} show lacp lag <group-id> {detail} jerry lacp enable lag <group-id>
Warning
LAG does not exist. Logical port, Lif instance: %lif%
| Name | Type |
| lif | String |
